Camper_G
Oct 10, 2013Explorer
I do have some calipers, thanks. I will try that.
What is "two squares"? I'm not familiar with that? are you talking using two swanson speed squares or soemthing and measuring the distance between them?
According to some research I've done, if you take the Circumfrence and divide by Pi (3.14) it gives you the diameter.
So I took 7.75 / 3.14 = 2.47 (diameter), so considering my measurements are off a bit, I'd say I have 2-3/8" axles.
Unless they used a 2-1/2" axle on these trailers? If that's the case I would think I could not use the Dexter 2-3/8" kit?
Or am I missing something?
Thanks.
Thanks.
