mkirsch
Feb 18, 2021Nomad II
If the truck is structurally sound and mechanically sound, then there is absolutely no reason it can't do what you're asking.
It's a whole other ball of wax if the frame is rotten from rust, or if the engine is tired and the suspension is all wallowed out. If you think the truck is in good shape, though, then it's capable. All you can do is try it out and if it falls on a pile, it falls on a pile. Then you simply didn't do your homework and ended up buying a heap. Has nothing to do with the capability of the truck as designed.
The only thing that can be said about it is, it won't be anything like your 6.7PSD, but you already knew that. There really is nothing else to be said.
