tempforce
Dec 05, 2014Explorer
what gear ratio does the van have, has the transmission been modified, i.e. a shift kit or reprogrammed? what tires are you running, size and ply rating.
what does the vehicle weigh and how much gvw is the rated for...
need more info, before any guesstimate may be made.
just swapping rear ends springs won't change what you can tow, unless it allows you to haul more weight. then you can tow less than if your vehicle is unloaded.
usually a conversion van weighs several hundred lbs more than a stock vehicle. (probably the reason for the 3/4 ton springs).
