HemlingExplorerJun 09, 20161998 1/2 ton vs. 3/4 ton both with 350cidWhat is the difference (besides the obvious engine) between these two rigs? Assuming the same suspension, transmissions and gear ratios, are they rated the same or does the big block account for a lot...Show More
BluegrassBillExplorerJun 10, 2016The weak point of a 1/2 ton is the brakes and drive line,U-joints and rear-end gears and yoke. Get the 3/4 ton.
Related Content1998 Georgie Boy fuse boxOnan 5500 Generator in Holiday Rambler 1998 Endeavor1998 Rexhall Aerbus??1998 Teton Kingman wiring schematic.1998 Fleetwood Discovery
