- NJRedneck1986ExplorerHello everybody just thought id say how i did and i finally found it after searching everywhere it was under the rear queen bed. :)
- AnOldCamperInCoExplorerThere should be a circuit breaker under the trailer on the back side of the frame rail behind the tongue hooked to the battery wire.
Jerry
2000 Chev 2500 Chev Suberban 4x4
1999 Wildwood T-22 Trailer
pulled over 100,000 miles - Locate the 120 volt circuit breakers, should be small metal plate adjacent to it held in place with thumb screw.
Could/should be a circuit breaker or fuse in the front where the battery cables connect to the TV ambilical cord. - NJRedneck1986ExplorerThanks everybody i will check it out tomorrow since its dark here and i will let you know. Im soo happy i joined this site :) thanks again.
- 1492ModeratorMoved from Forum Technical Support
- Sundance07Explorer
Camreal wrote:
Had a Mallard and they were behind the metal door below the refrigerator.
^^^^ Yep.
That's where mine were on my 2000 Mallard as well. - CamrealExplorerHad a Mallard and they were behind the metal door below the refrigerator.
- dodgerdogExplorerusually down near the front of the trailer behind a metal door.... Low.... I don't know your trailer layout...
Mike C.
44,071 PostsLatest Activity: Sep 17, 2026
