tnrv_er
Oct 04, 2015Explorer II
1st time winterizing
I didnt want to hi-jack the other 2 treads so I started another winterizing thread.....sorry fellas.
I've read through the other treads plus my owners manuel but I'm still not comprehending it!!
Other than my low point drain valves & FW tank drain valve under the camper the only other valves I have are 2 three way valves that go to the water heater.
This is the where I'm get lost.......in the owners manual they talk about a "by-pass" valve for the water heater, that would mean a 3rd valve correct?
So 1st question if I don't have a by-pass valve what do I do?
2nd question: theres no "kit" with a separate hose on the water pump, do I disconnect the water hose from the FW tank, that should be the suction side I assume??
Now the rest I think I understand but im gonna run it by you guys to make sure:
All tanks are drained
insert hose from water pump into antifreeze jug
turn on pump
open high point hot water faucet 1st,repeat on cold water faucet.
repeat above process on shower
then flush toilet until antifreeze appears in bowl
pour antifreeze into "p traps"
last drain water heater
Am I correct??
Theres no bathroom sink or outside shower.
Thanks
turn on pump
Am I correct??
Thanks
