blt2ski
May 13, 2013Moderator
One thing that should be noted. If you are over 10K lbs total, be it a half ton, mini truck with trailer, or just plain towing a trailer.......SOME area's you will have to follow the truck rules, such as chaining up in winter where chains are required for rigs over 10K. That is ANYBODY! Some places you can go into the carpool lanes, others you can not.
These are two things to think about if you are over 10K total wt! If you are registered as I was with my old 9200 gvwr truck at 12K, again, you have to follow the over 10K rules on some things! Your registered wt for the truck, not door tag can also mean what rules you have to follow in some instances too!
Marty
Marty
44,071 PostsLatest Activity: Aug 16, 2026
