VintageRacer
May 14, 2013Explorer
If the restriction is based on GVW, that means the gross vehicle weight of the vehicle as loaded at the time. That means that if your truck is loaded over 9K, you can't drive on that road, but if it's loaded under 9K you can. As noted, if the restriction includes a pass for RV's you can weigh anything you want as long as you tow the RV. GVW is different from GVWR - one is actual, the other is a rating not to be exceeded.
Brian
Brian
44,071 PostsLatest Activity: Aug 16, 2026
