johndeerefarmer
Oct 11, 2014Explorer III
Huntindog wrote:kep5niner wrote:That is interesting. I just went out and looked at mine. It has no separate rating for when the sleeve is used. I can't think of a logical reason as to why the receiver would be weaker when using the sleeve... It should feel the forces as if a 2.5 stinger were in place.
My limits were a little off, but the premise with the sleeve is the same. This sticker is located directly on my hitch.
The receiver is not weaker when using the sleeve. The tow rating is reduced because you are only using a 2" hitch. When you leave the sleeve out you can use the 2 1/2" hitch thus your capacity increases.
