brulaz
Oct 11, 2014Explorer
Huntindog wrote:
...johndeerefarmer wrote:No. Equalizer rates both drawbars the same. The Ford limitation has NOTHING to do with the drawbar. That is why it makes no sense. And probably why the others don't have a separate rating as well.
The receiver is not weaker when using the sleeve. The tow rating is reduced because you are only using a 2" hitch. When you leave the sleeve out you can use the 2 1/2" hitch thus your capacity increases.
Equalizer may rate both drawbars the same.
But a 2.5" sq drawbar has gotta be stronger than a 2" sq drawbar, all else being equal. So it does make some sense.
