Huntindog
Oct 11, 2014Explorer
brulaz wrote:Not really. If I take my 2" draw bar that is rated for 18K, and put it in my GM 2.5" receiver, I get the same rating as if it was a 2.5" drawbar. It is only the Ford that rates it different... Ford doesn't rate drawbars, only their receivers. What they are saying is that their receiver is rated for less when a 2" drawbar is used. What makes no sense is that when using the adaptor, the load force will be the same. GM and I believe Dodge see it that way, and don't use separate ratings.Huntindog wrote:
...johndeerefarmer wrote:No. Equalizer rates both drawbars the same. The Ford limitation has NOTHING to do with the drawbar. That is why it makes no sense. And probably why the others don't have a separate rating as well.
The receiver is not weaker when using the sleeve. The tow rating is reduced because you are only using a 2" hitch. When you leave the sleeve out you can use the 2 1/2" hitch thus your capacity increases.
Equalizer may rate both drawbars the same.
But a 2.5" sq drawbar has gotta be stronger than a 2" sq drawbar, all else being equal. So it does make some sense.
Another point, is that 2.5" doesn't have to be stronger than 2". It depends on the grade of steel used.
