Huntindog
Oct 12, 2014Explorer
brulaz wrote:Wear and especially slop also exist in a 2" receiver, 2" bar matchup. But it isn't a problem when WD is used, which takes up the slop when it is under tension. If you were to go without WD, then yes, it could be a problem down the road.Huntindog wrote:brulaz wrote:Not really. If I take my 2" draw bar that is rated for 18K, and put it in my GM 2.5" receiver, I get the same rating as if it was a 2.5" drawbar. It is only the Ford that rates it different... Ford doesn't rate drawbars, only their receivers. What they are saying is that their receiver is rated for less when a 2" drawbar is used. What makes no sense is that when using the adaptor, the load force will be the same. GM and I believe Dodge see it that way, and don't use separate ratings.Huntindog wrote:
...johndeerefarmer wrote:No. Equalizer rates both drawbars the same. The Ford limitation has NOTHING to do with the drawbar. That is why it makes no sense. And probably why the others don't have a separate rating as well.
The receiver is not weaker when using the sleeve. The tow rating is reduced because you are only using a 2" hitch. When you leave the sleeve out you can use the 2 1/2" hitch thus your capacity increases.
Equalizer may rate both drawbars the same.
But a 2.5" sq drawbar has gotta be stronger than a 2" sq drawbar, all else being equal. So it does make some sense.
Another point, is that 2.5" doesn't have to be stronger than 2". It depends on the grade of steel used.
Yes, I see your point. Using higher strength steel, a 2" shank could be made as strong as a 2.5" shank. I guess your 18K 2" draw bar is one of them.
Perhaps Ford is ignoring all that and simply assuming that a 2" shank is not as strong and putting that assumption into its ratings.
Unless there's some other mechanical issue with using a reducing sleeve that may concern them. Other than the potential for wear and slop, I can't really think of one.
