WayneAt63044
Nov 29, 2019Explorer II
I wear socks to bed at night when it is cold and plenty of quilts keep us toasty warm. Be sure the socks are fresh and dry; not the ones you have worn all day. Have done this in Quartzsite for years when the overnight lows are in the 30s. Running an electric blanket seems to me a waste of precious battery power when off the grid. I reckon a trip to KS in the winter is another thing. When we leave St. Louis for the desert in January the weather and temps determine if we travel through OK City and Amarillo or take a more southern route. Your KS trip is north of our northern route.
I, too, have wanted more battery charging from the tow vehicle but have never tackled that issue. Shouldn't be too hard to do with heavier wire routed to a separate connector added where the trailer connects to the tow vehicle and heavier wire to the batteries. I have always had 2 12V batteries in parallel as our TT has always had the space for both. We used an inverter generator every few days in the desert but then we were boondocking with no neighbors to disturb and our nearby friends did the same. Just didn't watch TV or run much electronic gear. It's a great time to read. I also used a 12V battery charger from an 400W inverter I added to the tow vehicle. We have survived 2 weeks that way without a problem. The issue was breaking camp to dump the holding tanks and resupply freshwater. Will you have to travel with the water system winterized? Just my 2 cents worth. Good luck, surely you'll get more useful advice/experiences.
44,068 PostsLatest Activity: Jun 01, 2026
