naturist
Nov 29, 2019Nomad II
As things stand right now, you have two wires going to one battery. To avoid problems later with uneven charging, put the positive wire on the positive terminal on one battery, and the negative wire to the negative terminal on the other battery. Then to complete the circuit and insure you keep it to 12 volts and not 24 volts, you need TWO short jumpers to connect the two positive terminals together and the two negative terminals together.
If you put one short jumper in and connect a pos to a neg, that will cause the very problem you seek to avoid. Print this out, cut off this paragraph, and do what the other paragraph says. You will be golden.
44,068 PostsLatest Activity: Jun 01, 2026
