opnspaces
Nov 29, 2019Navigator III
To hook up two 12 volt batteries you need to simply put the batteries side by side. Reference the picture below.
Then:
Ignore the disconnect in the picture if your trailer does not have one.
This will give you 2 twelve volt batteries wired as 12 volts.
As far as the hefty wire between the posts, I just use short battery wires with ring terminals at each end that I bought at Walmart next to the batteries. It's probably a bit overkill on wire size, but they were premade so it was easy.
- Use a wire to connect the negative posts together
- Use a second wire to connect the positive posts together.
Then:
- Connect the positive wire from the trailer to the positive post on one battery.
- Connect the negative wire from the trailer to the negative post on the second battery.
44,068 PostsLatest Activity: Jun 01, 2026
