pianotuna
Nov 30, 2019Nomad III
Hi,
I have dual #8 wire--capable of 140 amps of charging. I get almost none except when I run the inverter to power the microwave. The system does little or no charging.
If you wish to do serious charging beefing up the wire is not enough. Get a DC to DC voltage booster, and set the output to 14.6 (or what ever voltage below that floats your boat).
deltabravo wrote:Lwiddis wrote:
You’ll get minimal recharging via the tow vehicle.
Not if you do heavy duty charge upgrade like I describe in this video
The same technique can be applied to a TT. I will probably do this to my TT soon.
44,068 PostsLatest Activity: Jun 01, 2026
