jerem0621's avatar
jerem0621
Explorer II
Apr 10, 2022
2.7l Silverado, 7,200 lb TT Vs Monteagle
2.7l Crew Cab, 7,200lb travel trailer Vs. Monteagle Mtn…
17 minutes of Towing goodness for you all.
Monteagle Towing
Thanks!
Jeremiah
  • By way of comparison, the burb had the 8.1 with 4.10 rear but only a 4 speed transmission...I pulled our 8700 lb TT up that same grade in 3rd gear at 3200 rpm holding 60 mph...so cool to see a little 2.7 doing the job of old technology big blocks!
  • Admire your choices, setup, and know how
    GREAT looking setup to boot !
    Forced induction turns that 2.7L into a much bigger displacement when the turbo is full on and advise to keep up the maintenance to keep it going for a looong time
    Mainly engine oil (synthetic) and other fluids. If me, way before the computer says to change for added insurance
  • BurbMan wrote:
    215* is a little hotter than I like to see the trans get, although not terrible considering the Dex6 fluid is 100% synthetic now. If it runs hotter in the summer when ambient temps are higher I would consider a supplemental trans cooler.
    It's normal. GM doesn't consider it too hot until 265deg. Not that cooler aint better, but I think its thermostat at around 200. My 2020 runs close to 200, empty once fully heat soaked.
  • Impressive! Amazing the power they squeeze out of these little engines! 215* is a little hotter than I like to see the trans get, although not terrible considering the Dex6 fluid is 100% synthetic now. If it runs hotter in the summer when ambient temps are higher I would consider a supplemental trans cooler.
    Overall very impressive! Good luck with the new rig!
