97psdhost wrote:
Is anyone using a rear block lift kit on a ford f350 dually?
I have upper and lower stable loads and still have a little sag. I was thinking I could put a block lift kit on the rear axel and get the ride height back to level. I realize when unloaded it won't be level again, but it is worth it when loaded.
First, since you have a F350 Dually, are we to assume, based on your signature that you have a 97 model with the diesel? This makes a difference. I am only familiar with the Superduty (99-2010) models.
The Superduty incorporates a factory 3 5/8" block in the later models, and a 1 7/8" block in the 99 model and F250's and Excursions. Does your F-350 have any block now?
On my 2002 F350, I have the upper Stable Loads which was fine until I added a superhitch, and decided to tow a small ATV trailer. Due to the leverage, and tongue weight, I then added Air Bags. I only add enough air to level the truck, and make sure I do not dis-engage the bump stops of the Stable Loads. If you have the upper overloads, I have known a few guys that have doubled up the upper overloads to help level and not go to airbags. That is an option without going to blocks.
I hope that this helps,
Best Regards,
Garry in Kodiak, AK
