zackyboy3rs's avatar
zackyboy3rs
2 problems 1st time out. Please help.
2011 Sabre 31qbds. 9000 lbs. 35 ft
1. I noticed ALOT of bounce & movement while camping. TT has electric stablizers with the sand pads. I am thinking I need to order slideout stablizer jacks, x-block things for tires. Anything else?
2. New (previous owner installed) Bull dog electric tongue jack. 3500lbs. Returned home & unhooking I was using & all of a sudden the jack just quit. I did notice a black wire that I think is the ground wire(?). One end was loose but it also seemed like it did not go with the jack. Any advice?
Thanks.
  • It is normal to have bounce and movement. You're camping.
  • rav wrote:
    don't get slide out stabilizer- if the trailer drops from a low tire or soft ground and the stabilizer doesn't you will damage the slide. I would get the wheel chocks (x block things!). those should help with the front to back movement. someone else will have to chime in about bounce on your trailer.
    I would go on the Bull Dog website and look for an owners manual that could show how it is to be wired.
    ditto!
  • don't get slide out stabilizer- if the trailer drops from a low tire or soft ground and the stabilizer doesn't you will damage the slide. I would get the wheel chocks (x block things!). those should help with the front to back movement. someone else will have to chime in about bounce on your trailer.
