LarryJM
Sep 16, 2018Explorer II
ScottG wrote:
You would be better off making some adjustments to try and reduce the effect. More spring rate or more weight at front of trailer.
Also, a better hitch like the Reese Dual Cam with active sway control will both resist sway and push the combination back in line.
There are other brands that offer active sway control but I've not used them.
It appears you really do not understand these sway systems since the Reese DOES NOT RESIST SWAY and DOES NOT PUSH the combination back in line nor is it what could be called "ACTIVE SWAY CONTROL". The friction type sway bar sytems and the Reese and Equal-i-zer all are "FRICTION TYPE" sway systems .... they just perform the same function in slightly different ways.
Larry
44,067 PostsLatest Activity: Jun 05, 2026
