clarkgriswold's avatar
Jul 18, 2013
20 amp Circuit & A/C?
We just bought a new-to-us Funfinder Travel Trailer and need to check out the A/C. Unfortunately I don't have a 30amp receptacle at the house. Does anyone know how long I can run the A/C on 15/20 amp circuit?
  • What is important isn't time, it is the VOLTAGE inside the RV when the A/C is turned on.
    According to ANSI C84.1-1995 (R2001) any voltage below 110 volts for long term, or 106 volts for short term (seconds), may very well damage things in your RV (most commonly air conditioners, but anything could be damaged).
    So unless you like to live dangerously, get a voltmeter. If you are plugging into a house, you could still have a problem. The electric company could be providing a low voltage, you could have too much drop within the house wiring, you could have overloaded circuits, etc, etc, etc.
  • If you make sure that nothing else is being used (converter, etc) on your 110VAC circuit, the 20A circuit should work fine.....depending on the size of your A/C unit.
    Get a multi-meter, and when you plug in the camper (with the adapter), check the voltage at one of the outlets in the RV.....then start the A/C, and check the voltage again....if it drops below 105 VAC, you probably don't want to run the A/C very long.....but you should still be OK if it's above that.
    Good luck, and enjoy your new RV:)
