otrfun
Feb 10, 2019Explorer II
zzyzxpat wrote:If you're in the least concerned about weight, suggest researching the "realworld", empty/dry weights of these three campers carefully. You'll find the 995, especially the 865, will probably weigh at least 500-700 lbs. more than the NL 9.6. AF advertises the empty/dry weight of the 865 at 2,641 lbs. . . . which does not include the mandatory Fox Value Package which weighs 595 lbs. In reality, the 865 weighs 3,236 lbs. with no/zero options. Add some basic options and the weight easily increases to more than 3,500 lbs. The NL 9.6's empty/dry weight rarely exceeds more than 2,900 lbs. even when fully optioned.
. . . We want to get a new camper, either a NL 9.6, AF 865, or a Lance 995, not sure on a slide, trying to keep the weight down . . .
