enblethen
Jan 22, 2022Nomad
photo link
That is a DSI water heater
You need to follow the 12 volts from switch to circuit board.
Start by checking ECO and thermostat for continuity. Use ohm meter between the two red wires and then the two brown wires.
Behind the shrink tubing on the brown wires is a thermal fuse. check it for continuity and loose connections.
It sure could use a good cleaning!
44,071 PostsLatest Activity: Sep 17, 2026
