stupendous_man's avatar
Feb 18, 2022
2000 Lance 920, Battery Not Charging With Alternator?
Hi all,
I have a 2000 Lance 920 I recently purchased that is not charging the battery while underway with the truck. Everything is connected securely, the battery is brand new, and things are charging under shore power. The battery is powering the truck with no problems. I’ve inspected all the fuses, which were fine, and looked for any tripped circuit breakers, of which there were none. I also have looked at the wiring harness from the camper to the truck plug. This harness did have some nicks and cuts in it, and a bit of damaged/oxidized wire in those cuts. However, I didn’t see any evidence of a short, as there was no scorching. The cuts were repaired with electrical tape. The running lights are all working through this same plug.
Any insight on where to look next, what to try, what to replace, would be greatly appreciated!
