d3500ram
Feb 19, 2019Explorer III
zzyzxpat wrote:
I am looking to see if anyone has changed up their 16" wheels to either 17" or 18", ...
I would recommend against 17" wheels as an upgrade because the tire selection for increase Load Index is limited for this dimension. I have researched the sheet out of this size for my application as was able to make a Nitto 285/17 with LI126 work for me.
Truck mfrgr's went to 17's for the larger brakes for the clearance required. I learned this when researching the various options and wondered if I could go down to 16's.... the tires were vast, but the wheels would not fit my Dodge. I considered 18's but was able to run the numbers from CAT scale slips to make he Nittos work for my situation.
I have not looked at LI's and ratings for 16's in a long time but IIRC there seemed to be quite a lot of selection. If this is not the case anymore I would look closer at 18's bit in conjunction with higher load capacity tire, make sure to look at the weight capabilities of the wheels... what good is a capable tire if the wheels that host them cannot support it... wheels most likely could be the weakest link even with a qualified tire.
