LIKE2BUILD
Feb 16, 2016Explorer
VAfan wrote:
Having trouble with brake lines blowing on my 2001 Suburban. Happened twice; both times while towing my travel trailer. The most recent was last Sunday with the trailer hooked up for a trip to Fort Clinch, beach site #5. Fortunately happened on the road I live on and I was able to turn around.
First vehicle I've had with this problem; apparently this is common in Northern States.
Anyone with experience and have a recommendation for a brake line kit? Having a hard time finding one for a Suburban.
This is ridiculously common on GM trucks of this vintage. My buddy had it happen to his '00 2500, it happened on my '04 2500HD, my neighbors dad had multiple patches on his '03 1500, and I've heard of numerous others. Most often the failure happens to one of the feed lines from the master cylinder into the ABS block. Usually you get a nice puddle of brake fluid right under the driver's door.
The true fix is to PATCH NOTHING!!! I installed a complete new kit on my truck and it was a huge improvement. When I removed the old lines we tested different sections putting bending pressure on them by hand. Several sections just crumpled with very little effort. It's either poor corrosion protection in the metal or the fluid is so hydroscopic that the high moisture content eats it away. Regardless, in my opinion there isn't enough good metal in these lines to properly patch the OEM tubing and guarantee it won't bust again.
Dorman Part# 919148 is a stainless steel complete replacement kit for your vehicle. This is a job you can do in your garage with a 4 ton jack, 4 jack stands, and a Saturday. You might want to be certain that is the exact part number, but according to the RockAuto.com brake line info for 2001 Suburban this is supposed to be the right product. For $55 plus shipping and a Saturday this is a great way to ensure the safety of your family.
Do yourself a favor.....install a new kit and avoid future failures.
KJ
44,056 PostsLatest Activity: Jan 12, 2020
