AnEv942
Jun 06, 2017Nomad
The hitch, Curt C31014 mounts at bottom of frame rails, fog lights unaffected (if used) receiver comes out below air dam.
install PDF
I used a Hidden Hitch (Draw Tite) 65022, similar to Curt 31114. Receiver comes out just below bumper at tow hook level, fog lights removed (can be creatively modified to reinstall). Mine was a no drill, spacers used on outside bolts so inside bolts under bumper flanges, not sure why they changed.
install PDF
So that would be my only comment, verifying the height of receiver that works for you.
As to torque values, one of my pet peeves. Any bolt that needs to be removed to install after market item, factory torque # should be supplied to reinstall.
Front spring bolt/nut is like 203# (installing the C31014)
the blocker beam nuts 76#
install PDF
install PDF
