Celica77's avatar
Celica77
2002 silverado 1500
I know it has been asked about a thousand times but what can my truck tow? It is a 2002 1500 extended cab 4x4 5.3l. 3.73 gears. From what I am seeing is 8000lbs. My truck invoice says it has the tow package, which includes, transmission cooler, locking rear diff, heavy duty suspension, 8 wire trailer harness. So just curious if with that if the tow capacity stayed at 8000lbs.
Thanks
  • Pulling should be fine. Lifting the weight might not be. What’s the 2002’s payload max?
  • Truck payload is likely your issue. 8K trailer is likely 1000lb hitch weight plus whatever else is in the truck including passengers.
    Look on the door jam. There is a sticker that shows the payload as it left the factory.
    The other thing to consider is at 20yr old, is the engine and transmission in good shape?
  • While that will likely be a load for your truck, sounds do able to me. Not sure of your travel area, but steep hills, or mountains will require lots of patience.
    Welcome to the forum!
    Jerry
  • I have a 2004 weekend warrior fk1900 Hitch Weight 650lbs Dry Weight 3887lbs.
    Family of 4, will see 2-3 dirtbikes in the back of the trailer. Maybe a generator in the bed of the truck and the usual food and water in the tanks.
  • Yes, you should be able to tow 8K. The misleading part...an RV trailer normally has a large frontal area, and huge sidewalls. If you are towing a flatbed trailer, with a load of bricks 8K would tow much easier.
    You also need to be aware of hitch weight, as an 8K travel trailer may have 1K+ of hitch wt.
    Looking to tow a TT with an older 1500 V8 3.73, I'd suggest staying at 7K or less actual ready to camp wt. If you have 4 passengers plus gear and lots in the bed of truck, that needs to be figured in too.
    Jerry
