subcamper's avatar
subcamper
Explorer II
Apr 08, 2015
2002 Suburban K2500
I have a 2002 Suburban K2500 with the 8.1L engine. The muffler has developed a few holes in it. I temporarily patched it with a piece of sheet metal, pop rivets, and hi-temp RTV. The pipes seem in good shape.
Our local muffler shop chain says they don't list an aftermarket exhaust system for it, or even a muffler. He says the muffler should be similar to a 2500 pickup, so bring it in and they'll see what they can do.
Anyone replace a muffler and/or exhaust system on a sub like this?
I did find a post by BurbMan back in 2012 where he installed a Flo-pro muffler that sounded like the stock one (I don't want a louder muffler). If you are reading this BurbMan, how has the muffler worked out? We have bad winters here and I was hoping for a stainless muffler. I think the Flo-pro was not stainless.
Steve
  • Hi Steve !
    Yes, the SS rings take longer to seat and more important on how it is seated than
    other ICE's
    It has to do with the metal movement from the hills and not cover
    the valleys. To form plateau's as landings for the rings and the
    valley's to hold oil that will be swept up by the rings to the plateau's
    Key is to NOT shear the hill tops off, but to mush them flat...
    Wondering if my 7.4L has SS rings? It does NOT consume engine oil...even now at
    +164K miles of extremely hard driving as a 'car' and towing a +8.5K boat
    Only consumes engine oil when the oil has been beat up and losing it's film
    tension rating. That is when I know it is past time to change oil/filter...when
    the dash oil gauge fluctuates and drops a bit in PSI
    As for the muffler, I'm not looking too for my 7.4L and will check out the maker
    you guys are looking at. Made a mistake taking out the OEM and replacing it with
    a Magnaflow (2 in, 2 out but with a common chamber...therefore Cal SMOG says a
    single).
    Actually lost a bit off idle. Almost a stumble. Lost was the low end scavenging
    High end is significantly better than OEM...but also lost was stealth via silence
    A trick I've been using since the 70's was taught to me by old man Sanderson
    when he taught me HOW2 make my own headers
    Get a few bottles of aluminumize anti-seize and 'paint all the bare metal seams
    and even galvanized portions
    The heat will burn off the oil carrier and plate the metal with aluminum
    The muffler shops that guarantee life time muffler make their money in replacing
    the rotted out tubing...even aluminumized...the welded seam isn't plated with
    anything and will rot from that to the rest of the tubing
  • subcamper wrote:
    I talked to an engineer at the Tonawanda, NY plant that built the 8.1 engine. He said the oil consumption is due to the fact that it was designed to also run on natural gas. The rings had to be made of a harder material, which don't seal as well as softer rings.
    FINALLY...the best explanation I have heard about this. I know when the 8.1 was new back in 01-02, the Internet was covered in complaints and warnings about "piston slap" because the engine is so noisy started cold. The noise coupled with the oil consumption had many yelling that "the sky is falling" and demanding that GM replace or repair their 8.1's.
    I always wondered why GM didn't issue a TSB to the effect that these "complaints" are normal. All I know is I did a Blackstone report on the last oil change and this thing running like a top!
  • Thanks for the replies.
    Just thought I should post my experience. I went to the high mileage synthetic oil burbman suggested. I also went up one grade in viscocity. I needed to add about 1/2 quart after just under 1000 miles. I'm fine with that. Looking back, it was probably low quality oil from my last change. I went to one of the express oil change joints. I don't know what they use or what their track record is as I have rarely used them. I'll do it myself with high mileage Mobil One from now on.
    Funny part is I did 9000 miles towing last summer and burned 1/2 quart every 1300 miles. I was fine with that too. Then I had the oil change and was burning two quarts or more per 1000 miles. I thought I was in TV hell. And I don't have money for a new one.
  • I'm a big fan of Magnaflow exhausts/components. #15716 is the cat back system replacement. Otherwise, you can measure the inlet diameter, outlet diameter, length and width of the OEM muffler and use Manaflow's muffler lookup to find a direct match. Any competent muffler shop can hack in nearly any muffler.
