jerem0621
Apr 27, 2016Explorer II
You pretty much have it figured out...you have discovered the answer to the Riddle my friend BenK often uses...I am paraphrasing some..."HowMuchCanITow....HowMuchShouldITow???" And the answer is not the same for everyone.
As a suggestion, and a consideration...you may be able to gain a few hundred lbs by changing vehicles to a crew cab truck...but if going through the trouble to change vehicles I would step up to a 3/4 ton truck and gain 1,000 lbs plus wiggle room (depending on the truck, not all 3/4 tons are created equal)
Thanks!
Jeremiah
Thanks!
Jeremiah
44,071 PostsLatest Activity: Aug 30, 2026
