PAThwacker
Oct 17, 2019Explorer
Drains to fresh water tank and low point drains should be there . If none hook up airline and blow out our all lines. Follow up with winterize. If no draw by water pump you can add one. Very simple add with parts at any plumbing store. Next go to water heater to see if it has a hot water bypass. If none you need 6 gallons of antifreeze in the hot water tank. Hot water bypass can be sourced at chinazom.
