galexander
Jun 05, 2014Explorer
Price is always negotiable. Check out camper real good, go up on roof and walk around looking for soft spots, old cracked caulking, tears in the membrane.
Inside, let your nose do the checking, if you smell a damp musty odor, or any other odd odor, there probably is or at one time was a leak and there may or may not be a mold issue. Check corners of the campers, check inside cabinets in the corners and bottom areas for damp or soft spots. Check bunk end door seals and caulking around outside of bunk end. Be through and take your time checking things out. Good Luck.
44,068 PostsLatest Activity: Jun 17, 2026
