I have a 2004 Dodge Duelley with a 5.9 Ho in it.. the other day I stopped at a red light. When I pushed the petal to continue it would not get up to over 40mph. I stopped and turned the engine off a...
Apps is the same as a tps, throttle position sensor I replaced mine at 60 k. It went suddenly when it went. Mine had codes that vaguely indicated errant throttle voltage also I replaced the apps and no more problems. I still checked fuel psi first.
