jmtandem wrote:
looking & trying to decide on which truck to purcase. 04 has 96000 miles Nd air bags, 06 only has 79000 miles both trucks equally equipped. both trucks are florida truck 04 is 2200 cheaper than 06 . any input from you all would be appricieated in try to decide
I would get the '06 if both were in the same condition. The '04 may or may not have 48re transmission that is better than the previous 47 that supposedly was transitioned out with the 04.5 model year. Also, the '04 may or may not have the 325/610 HO engine. The '06 for sure has the 48re transmission (unless it is a manual transmission) and the 325/610 HO engine. Also, you might want to look at the axle ratios to be sure you are getting the one you want for towing. Most duallys came with at least a 3.73 and many a 4.10 ratio.
I believe is was only the early 2003's that still had the 47RE and lower HP/TQ.
