crcr
Jul 15, 2018Explorer
Grit dog wrote:
Can't help with what sort of 5ver. Anything under 12-14000lbs is a good match though in general.
Couple things about the truck, if it's in good shape and you're planning on keeping it for a long time.
1. Ditch the OE 17" wheels. You can find OE 18" or 20" takeoff wheels and tires cheap and they will have more available tore capacity and choices.
2. Stock 3rd gems leave a little to be desired in the power department when towing gets heavy. With a stock trans you can do a mild tow tune that won't destroy the trans. 30-40hp and 60-80 ft lbs bump in power. If you are serious about making th ole 05 a real towing beast then a built trans is in order and you can bump up 100hp or more easily.
3. Exhaust brakes are worth the $ IMO. I'd doo this first before any other mods.
4. The above 3 mods are the only things you would need to do to make that truck hang with a brnad new one up and down the Mountain. But you're looking at about $7k min to accomplish that. 3k or so for the exh brake, programmer and some new wheelz would get you mostly there except in the power department. The rest of the truck is already built to handle whatever you can throw at it.
Last thing, how many miles, how many miles on injectors, and do you have additional fuel filtration? That is the most important thing to look into IMO on 3rd gens.
A lot of owners, myself included only get 100-150k on OE injectors without additional fuel filter. OE filter is not up to par. 2micron add on kit is $200 if you buy one manufactured, or about $50-100 if you make one. Either is worth it....today.
I own a 2004.5 Ram Cummins. I would agree with most of these suggestions, except -- there is no need to switch from OEM 17" to 18" or 20" wheels. And in fact, switching to the taller wheels will likely raise the height of your truck, which in general is not helpful when trying to tow a fifth wheel level. The rear axle rating on these trucks is 6000 lbs. Michelin tires on the stock rims have a weight rating of right at 6400 lbs, so if one were to switch to 18" or 20" wheels as suggested, there would be no gain in payload capacity whatsoever.
You could switch wheels for cosmetic reasons if you like, but there is no performance gain to it. I switched to 17" 4th Generation 2500/3500 Ram wheels, for both the appearance and the slight weight savings with the newer OEM alloy wheels as opposed to the 3rd Gen Ram steel wheels. I stuck with the stock size Michelin tires.
I also had the transmission built. I haven't put a tuner on the truck yet, but I have the option now of adding a mild tune... I'm the second owner of my truck -- I was very fortunate in that the original owner added a PacBrake. I highly recommend installing an aftermarket exhaust brake for towing... I will be installing an additional fuel (and water) filtration kit shortly -- that is an excellent upgrade... I have 153,500 miles on my truck, still on original injectors.
Good luck. They are great trucks!
44,065 PostsLatest Activity: Apr 13, 2026
