larry_barnhart
Apr 02, 2016Explorer
45Ricochet wrote:LIKE2BUILD wrote:
The 2005 Duramax had some issues with overheating due to air restrictions in the intake design. It's possible that under your towing load that air restriction came into play and the engine was running too hot.
X2
Common problem with some of them. I have forgotten the name but a company in Utah made a Induction Overhaul Kit, nice aftermarket item to fix it.
Maybe Larry Barnhart will chime in soon as I believe he has one.
I do have the air system but mine was from Arizona by killer bee. I have never had an overheating issue. I also have the scanguage11 that shows the correct water temp. I do have one issue for the last 3 trips south when towing at higher elevation going up mountains. The intake air will spike and the fan will come on at a low speed but full blast at times. engine temp will be 197 so now I wonder if an air sensor or etc is making the intake air rise in temp. this shows on the scan guage. Not really an issue but is a new problem maybe. I might look into it this summer. Never had a cel light come on to really give you any help. My truck has been maintained to extreme overkill.
chevman
44,066 PostsLatest Activity: Mar 14, 2015
