ceaser_22000's avatar
ceaser_22000
2005 6.6 duramax check engine
I have a 2005 GMC Duramax 6.6 while recently coming home through Virginia and West Virginia on North 77 my check engine light came on after about 3 or 4 good mountain passes. Stop for the evening the next morning the engine light came off pulling through the Flatlands no check engine light I don't have a obd reader any ideas I was pulling a 40 foot fifth wheel approximately 13000 pounds.
  • LIKE2BUILD wrote:
    The 2005 Duramax had some issues with overheating due to air restrictions in the intake design. It's possible that under your towing load that air restriction came into play and the engine was running too hot.
    X2
    Common problem with some of them. I have forgotten the name but a company in Utah made a Induction Overhaul Kit, nice aftermarket item to fix it.
    Maybe Larry Barnhart will chime in soon as I believe he has one.
  • The one thing that I learned about a Duramax is that to need to be able to read and reset engine codes.
  • Get Autozone to read the code for free. Then we'll all know.
  • And Your question is?
    Without reading the stored codes there is no way to know. BTW if you have an android smart phone, download the app Torque, amd buy a bluetooth ODB dongle off of ebay. That will give you way more than just a basic code reader.
  • The 2005 Duramax had some issues with overheating due to air restrictions in the intake design. It's possible that under your towing load that air restriction came into play and the engine was running too hot.
