ggardne2
Mar 12, 2014Explorer
Most likely truck needs an alignment ... Ford trucks are also pretty sensitive to road crown ... I find that when the alignment is perfect the steering wheel will always be a touch off-center to the left when riding the right lane. Switch to the left lane and the steering wheel will switch the other way. Unless the truck has a very noticeable drift/pull that causes it to wander in the lane or if you are getting excessive front tire wear I wouldn't bother with an alignment until you put new tires on the truck.
44,068 PostsLatest Activity: Jun 17, 2026
