Phils
Mar 17, 2014Explorer
Anson wrote:Anson wrote:anyone have an idea of how to check to know if it is a ball joint or a U joint?Anson wrote:So today I took it out again and noticed when I turn to the right I have a knocking sound in the front end, so im guessing a ball joint or a tie rod, any thoughts.
when I drive down the road and let go of the steering wheel the truck will start to pull slightly to the right, even harder when in 4X4 mode. thought I had a bad caliper but everything seems to be ok with them, any ideas on what may be causing this, Thanks
You can check the ball joint. Jack up that corner then with a pry bar located beneath the tire, leverage the tire/wheel up and down to see if there is any play.
Phil
44,068 PostsLatest Activity: Jun 17, 2026
