AnsonExplorerAug 28, 20142005 F350 DO I HAVE TO PRIME THE TURBOI rebuilt the Turbo last nite and cleaned it up, the vanes were stuck. So now im curious if I have to prime the Turbo before I crank it over. or if just running the motor will be good enough. Thanks
K_CharlesExplorerAug 28, 2014Did you "rebuild" it or clean it up? If you truly rebuilt it then you know it needs oil before it starts spinning.
Related Content2005 SixPac D850 WiringTurboOverhead Cab Leak on 2005 Winnie MinnieDuramax TurboTurbo leak
