AnsonExplorerAug 28, 20142005 F350 DO I HAVE TO PRIME THE TURBOI rebuilt the Turbo last nite and cleaned it up, the vanes were stuck. So now im curious if I have to prime the Turbo before I crank it over. or if just running the motor will be good enough. Thanks
Cummins12V98Explorer IIIAug 28, 2014When changing turbo's you should add oil to the supply line hole and spin it by hand so the bearings are fully lubricated.
Related Content2005 SixPac D850 WiringTurboOverhead Cab Leak on 2005 Winnie MinnieDuramax TurboTurbo leak
