Sport45
Aug 29, 2014Explorer II
eHoefler wrote:
I use a socket on a breaker that fits the turbine nut on the intake side. While using the socket on the nut, I have someone else start the truck, I keep the turbo from spinning for about 30 seconds. This allows oil pressure to build and fill the galleys on the turbo without spinning, then let it go.
If you do this I recommend shutting the engine down after the 30 seconds and not removing the socket until the turbine quits trying to spin. I wouldn't want to take a chance on the socket slipping off the breaker and bouncing around in there.
Pre-lubing during assembly should suffice.
44,068 PostsLatest Activity: Jun 01, 2026
