BUB1988's avatar
BUB1988
2005 Star Craft Travel Star
We are looking at a 2005 Star Craft Travel Star and was wondering if there is anything special we should pay close attention to.
The day we looked at it the area had gotten about 6 inches of rain, with lot of wind, and there was nothing wet. With that in mind I'm thinking there are no leaks. Did not find any soft spots in the walls or flooring and all storage areas were dry.
The slide went in and out okay, but at the end of the travel it sounded like gears slipping. I assumed that maybe the stop switch, not sure if has them, are not adjusted correctly. Is this normal operation?
It also has no manuals so there are some switches inside of the door we can't figure out what they go to. Three of the Five something, bead light, ceiling light, and outside light. The other two switches not a clue:?
Is there any place to find owner manuals for this?
Thanks
jim,
  • Hey mbopp
    Thanks for the reply. I wasn't sure how the slide worked. We are picking up the camper on Friday.
  • We had an '05 21SSO. The racheting sound is the clutch on the slide, it's to prevent the motor from running to stall.
  • The trailer is a M-21SSO. From the previous replies the unknown are most likely the Step light and the Dump Valve light, if this trailer has them. We know two of the switches operate the night light and the overhead light. The only one of the switches left is the porch light, that didn't have a bulb.
    Thanks for the reply on the manuals.
  • my 2006 had three switches on right side down next to floor one was nite light one was step light and one was dump valve light the two up high on left were overhead and outside porch lights manuals don't tell what switches are
  • POPUPPORTAL.COM has a section on the main page for "Camper Manufacturers & Manuals" that contains a library of hundreds of owners' manuals.I only have three of those switches you mentioned in my '07 TravelStar(porch light,overhead light,and floor night lights).
  • I traded in a 2006 travelstar 30qbs which switches are you talking about the ones on the left up high or down low on the right also what model trailer is it
