jlrosine's avatar
jlrosine
2005 Yukon XL Denali tranny whine while towing/braking?
Hi all. Yesterday I gave my 2005 Yukon XL Denali a pretty heavy tow test, and it maybe failed a little but maybe not? I'm trying to figure out if anyone else experiences this with their GMC trucks with the 6.0L or other Denali (AWD) systems.
Trailer: 2017 Jayco Jay Flight - dual Axle 5000lbs dry, I was probably at about 5500lbs yesterday.
Tow Vehicle: 2005 GMC Yukon XL Denali 6.0L AWD - 158,000 miles.
Recurve R3 weight distribution/anti sway.
Tow Route: Started at 4900ft elevation, drove i-70 in Colorado to Silverthorne from the front range. It's a 6-7% grade off and on, reaching 12,000ft I believe at the highest point then dropping down the "ike gauntlet". (93 miles)
The trailer tracked wonderfully, I had no issues controlling it on the way there and I used tow/haul mode the entire trip. The Yukon didn't sound much different than it ever does other than higher RPM, it ran fine and I was able to go about 50mph even up to the top of the gauntlet which isn't bad at all for power, I got about 11.4 MPG average over the entire trip. My issue comes with the transmission noise.
At about 30-45 minutes in to the trip, I had been climbing for a while and we went over the crest of a hill. I lightly tapped the brakes and heard a really weird whining noise, sounded almost like a power steering whine. This only happened when I would brake, the noise came from the front of the vehicle and at first I thought it was ABS/Brake master or something like that....but it wasn't. It progressively got worse, then the transmission would make the same sort of whine any time I used it to engine brake. I believe it was likely due to the amount of stress that is put on it pulling up grade, but it never slipped/clunked etc.
Max transmission temp on the gauge was probably around 230-240 at the worst, as I descended it would drop back down to 180-200.
The noise seemed to have a direct correlation with the temp, any time it was about 215 or higher it would whine more, and whine while braking (weird).
Long story short, I made it home, drove about 300 miles total with trailer and the Yukon seems fine, the transmission doesn't really whine while disconnected from the trailer, it feels normal as it has in the past, but I imagine it's just not good for it.
My gut feeling is that it's just too hard on the AWD system. At first I was a little stumped why it would whine/cause noise while braking but it makes sense because the front drivelines are never disengaged in the Denali. When braking, I'm also applying pressure to the transfer case which wouldn't occur in a non AWD system, at least with the front brakes.
I really like the way it towed but I'm pretty concerned that if I do this over and over, eventually (probably sooner rather than later), the transmission or transfer case is going to fail. I would really prefer a selectable 2wd/4wd rig to tow, my options are limited though (need to seat 6 people). I'm thinking about looking at either a Nissan Armada, Toyota Sequoia, or Ford Expedition EL with 3.5 EB.
I would love to hear if anyone has the same drive system I have and experienced the same thing...or even if you have a non AWD with similar noise?
  • X2. You're either loosing fluid viscosity, or its foaming. Or both. And neither are good.
    You definitely need a full fluid exchange at a minimum, and if temps are still that high with new fluid, than maybe consider another cooler.
  • Flush the transmission fluid. Maybe install an even larger trans cooler. Those are cheap changes before replacing the vehicle. 240* is a little high, but you tracked the sound/vibration to 215* which is in line with your towing conditions. Also, you may want to force the transmission to stick to 2nd gear. Shifting and more specifically unlocking the torque converter drives up the heat to 230+.
    If you are looking at newer tow vehicles and continue to tow at those elevations, I highly recommend the Expedition with 3.5L Ecoboost. Forced induction will not lose as much power at those elevations and the peak torque in the 2500rpm range will not need to shift as much.
