DirtyOil
Oct 09, 2017Explorer
Get your buddy to lay on his best side in front of truck while, you turn the steering wheel lock to lock. Your buddy should be watching the points where the track bar mounts to frame and front axel, any play means new bushings/track bar. As for an adjustable track bar, if he has a levelling kit or lift kit, he should install one. All the adjustable track bar does is center the front axel (right to left) when any kind of lift is installed. When you install levelling or lift, you are essentially changing angle of the track bar, which in turn pulls the front axel to the right side of the vehicle, then your truck "dog tracks". If he has a stock height truck, an OEM or aftermarket track bar is all he needs.
