darr wrote:
116,000 miles on truck..took it in for air condition but the guy said it was running ruff which it was a little...so they kept it took the infectors and had them tested and said they all needed to be replaced....no other problems with truck before this
Take it someplace else.
Their statement doesn't make sense when it comes to Common Rail injectors. Unless they charged you to remove and reinstall, and then sent them to Bosch, they did not have them tested.
Also, at 116K they are not all bad. No way. No how.
Injectors are replaced by inexperienced techs way too often.
Here's what can be wrong:
1. Carboned up injector tips.
2. Your Cross-over tubes need to be retorqued to the revised spec.
3.You have a failing coil on one of them. As the previous tester said, this is an easy fix. It's also an easy find for a decent tech.
4. This one is not likely at your mileage but you may have one or more injectors with an excessive return rate. If this is the case then your Grid heater indicator may come on while driving down the road even at speeds above 15 or 20 MPH.  This is the ECM's method of alerting the operator to this condition.
First thing to do: Change your fuel filter and fill the canister with SeaFoam fuel treament. Run the eng for about a couple of minutes so it gets to all the injectors. Shut the eng off and let it sit over night.
If that doesn't fix it find a private shop (or another dealer with a
certified Cummins tech) that says they can do an injector flow return rate test. If it fails the test or is even close, have them retorque the cross over tubes to the revised spec (which I believe is 42 lb/ft).
The reason your technician wants to replace all the sticks is because he doesn't know how to trouble shoot it. He only thinks that if he replaces everything he it will likely fix the problem.
That would be a huge waste of money and the reman injectors will not be nearly as good as what you already have. It would fix the problem for a while because he has to retorque the tubes during the replacement. But eventually those reman parts will start having new problems.
