Marshfly wrote:
timdan94 wrote:
don't bet on the 855s being much lighter.
Mine is option as follows:
-Day/night shades in cabover/dinette
-entry door pull shade
-sink cover
-magazine and spice rack
-wardrobe light
-removable clothes rod
-microwave
-fantastic roof vent
-ac coleman 11 high efficiency wall control
-led patio lights switch controlled
-docking lights
-battery separator
-second battery compartment
-awning rear door
-awning slide out cover
-swing out entry assist handle
-w/h bypass and winterizing valve
-insulated lp and batt compartment
-insulated bed pad
-insulated hatch covers
-furnace upgrade dual btu 15/22
-dual pane windows
with options and batteries it weighs 3294 lbs
On the contrary, this is almost 600 pounds (almost 20%) lighter than 6pac's scaled weight above. That's a lot of weight.
I can tell you that on my 3500srw crew cab I'm at 4820lbs on the front and 6720 on the rear axle for a total of 11540lbs. That is with nothing in the camper and I mean NOTHING... I was on the way home from the dealer I bought it from. It was just my wife and myself in the truck. the 855s will still put you overwieght with little gear in the camper. I had to order 19.5 tires to be able to carry the load.
