ib516
Mar 08, 2015Explorer II
You should be fine. The most common failures on that era of truck are front end parts and water pumps. I did both on mine. Check the "weep hole" on the bottom of the water pump for any evidence of leaking.
Check to make sure all your injector fuel lines are tight, some like to vibrate loose, let in air and cause that rough start.
44,068 PostsLatest Activity: Jun 17, 2026
