bikendan
May 09, 2014Explorer
first, which model did you get?
second, what is your tow vehicle?
third, have you checked the battery on the trailer?
just so you know, you have some things that are 12vDC that run off the battery and some things that are 110vAC only.
the trailer's converter will convert 110vAC shore power to 12vDC to run the 12v stuff and recharge your battery.
fuses are for the 12v stuff and breakers are for the 110v stuff.
they should both be behind a panel door, that also gives access to the converter.
my initial guess is that the trailer has a dead battery that drained your tow vehicle's battery while sitting hooked up.
44,056 PostsLatest Activity: Jan 12, 2020
