LittleTraveler's avatar
Feb 14, 2017
2006 Rockwood Roof Replacement
Bought a 2006 Rockwood Ultralite. The roof has some water damage and we want to repair with new luan panels and rubber membrane. My question is that since this roof is a vacuum bonded roof, are there any rafters to attach the new material or can we modify and put rafters with roll insulation, since I do not have a vacuum press to bond a new roof? Any suggestion would be greatly appreciated.
  • LittleTraveler wrote:
    We thought about just tearing out the damaged luan and sheeting over , but the interior luan sits on top of the wall, so I was concerned with how to attached it to the old luan. Maybe some adhesive and trim molding. We were looking at using a TPO membrane from Alpha. Has anyone used this product? Thank for the suggestions!
    Let me know how the interior fix goes and what you did. I have some water damage inside the back left section above the bunks. Would like to fix as some point but just have not gotten there yet and would like some feedback on how your fix goes.
  • We thought about just tearing out the damaged luan and sheeting over , but the interior luan sits on top of the wall, so I was concerned with how to attached it to the old luan. Maybe some adhesive and trim molding. We were looking at using a TPO membrane from Alpha. Has anyone used this product? Thank for the suggestions!
  • Welcome to the forum and best of luck on your endeavour! I can't offer you any help to your question, but want to through out a suggestion to you... Consider alternative roofing ideas, rather than the standard EPDM material. There is a member here Edatlanta (or something like that) that had a spray on material, similar to bedliner, but specifically made for RV roofs, and he LOVES it.
    EPDM is a great product for manufacturers... it is cheap, easy to install and lasts long enough for most RV owners not to complain about. However, if I was going to replace an entire roof system, I don't think I would go back to EPDM. I believe the material is from rvroof.com
  • There are rafters. It may be possible to remove the roof sheeting but it is going to be a chore and a mess. If the luan is also attached to the foam, you are in for a real struggle.
    An alternative way to repair this may be to attach new plywood sheeting onto the damaged sheeting that exists. Typically the damage will be contained to just a few small areas. If the original sheeting is really bad, pull and repair that and then overlay with the rest.
    I know they sell roof membrane kits that will have the membrane and the adhesive to apply but if you buy EPDM and adhesive at a roofing supplier, you will save money.
    Good luck with the roof repair.
